How do i pull quarter windows?
Take off the seat belt bolt on the topside of the interior panel. If I remember correctly, you will have to remove the roof sill panel which just clips into place. I also removed the bottom half of my rear seat ... very easy just push down and pull out on it. You will have to take out a majority of the screws on the interior sail panel as well. Pull the panel back and you will see some recessed nuts. Take these off using a socket but MAKE SURE THEY ARE ALL OFF!! I cannot remember the exact number of studs on the window but many people brake them by failing to take off all the nuts. Once you get these off, pull the window from the outside. There will be a good amount of windshield sealant around the factory window so take your time. This stuff is sticky too. Make sure you put window sealant on prior to re-installation. Good luck.
