How Do I Seal An Aod Pan? Silicone?
bcmbcmbcm
Jan 29, 2003
455
Hey folks, I know this must sound like a dummy question, but how do I seal an AOD pan to the transmission case? Do I have to use sealant or us the gasket ok on its on? If so what type of sealant?
Lastly, how do I tighten the bolts? In what sequence? Should I use common sense going around in a criss cross pattern? Thanks in advance!
I always just used the rubber gasket.
I've never had a leak.
What I will say is that while you have the pan off, put a drain in it. Not sure if the pan on an aod mustang is the same as the aode on my explorer, but there is a bung right in the bottom. Makes fluid changes about 1000 times easier.
