custom89stang said:yeah, from what i heard and advice i got before, the screw is in the throttle body that can change the idle, u can set it higher
92MNstanger said:You can do that, but remember that you have to reset the tps voltage after you move the screw. I always set my tps voltage to .95
The other way you can adjust it is to get the idle adjuster available form Ford. It installs in ten minutes, and works pretty slick
Michael Yount said:The computer tries to control the idle speed using the iab/c solenoid. It's preset to control around 625-725 rpm. If it can't control there, that means something isn't doing it's job, or you've changed something in a way that it can't compensate. I'd start off by removing the iab/c solenoid and throttle body and thoroughly cleaning them. What usually happens is that oily deposits foul the solenoid so that not enough air can bypass the throttle plate to maintain idle. The screw being referred to is more throttle stop than idle adjustment. You can try opening up the throttle plate a bit more and see what happens. Sometimes it works, sometimes it don't.
5spd GT said:Well what happened is I put new plugs in the car Autolite 25's...(gapped around .054), cleaned the air filter (was pretty dirty), new fuel filter, and I took off that solenoid and cleaned it with carb cleaner (didn't clean the TB...but the solenoid looks much better)...and after I did that the idle is about 100 rpms lower if I were to guess...and now I have to rev the car up about 2x as longer(steady gas) for it stay idling by itself...![]()
...but I know the idle is lower...Michael Yount said:Lower idle speed slows down both your water pump and your fan rotation speed - so a bit warmer in traffic might occur. 'Course, it's getting to be that time of year too.
