  • 1994 - 1995 Specific Tech
How do I set throttle screw
  • Thread starter Thread starter 1smoothmustang
  • Start date Start date May 19, 2006
1smoothmustang
11
  • May 19, 2006
Have a 95 gt. need to know how to set the hex screw that is sunken in on the top side of the throttle body ( do i unplug any connections, tape anything off, reset the computer , etc.).its to the left of where the iac installs. it is said to adjust how far open the butterfly is on the throttle body.thanks for any help.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 19, 2006
  • May 19, 2006
I'll be happy to give you some general info and a ballpark way to set up your throttle body
First thing is, that allen screw is not your idle speed adjustment screw. It is an air bypass screw that works along with the isc.
Second thing is, the screw on the side of the tb. That also is not an idle speed adjustment screw. That screws purpose is to keep the throttle body blade from sticking to the bore of the tb when the skinny pedal is slammed shut.
The idle speed is controlled by the pcm.
If you have either or both of these two screws very far away from their optimum range of adjustment, the pcm will compensate and attempt to set your idle speed to the pcm programmed value.
There are good articles on this forum with all the details but here is the ballpark setting I promised that will get you started.
Back off the linkage screw until it no longer touches. Tighten 1/2 turn past the contact point.
Completely close (don't tighten it hard ... just to point of contact) the allen bypass screw. Open it 1 and 1/2 turns.
Do a pcm reset with these steps ..................
Disco the neg batt cable
Turn on the headlights for 10 seconds
Turn off headlights
Reconnect batt cable
Drive around enough to where you have a combined idle time of about 30 mins to give the pcm time to adapt to various idle driving conditions.
If the idle is not stable at this time ....................
DON'T hose with the linkage screw!
Turn in or out, the bypass screw 1/4 of a turn for each adjustment giving the pcm time to adapt before trying another adjustment.
Thats how I'd do it
Grady
1smoothmustang
11
  • May 19, 2006
when u say at the end to turn the screw in small increments and give the pcm time to adapt did u mean to go back through the disconnecting of battery, turn on headlights, etc or simply give it a few moments to settle in to the new adjustment? thanks for the time. been alot of help
legalize420
1,541
South Florida
May 19, 2006
  • May 19, 2006
at that point you would not disconect the battery. give it a day or two before the next adjustment if necessary.
HISSIN50
34
129
May 19, 2006
  • May 19, 2006
I would also add (to the wise posts before me) to write down EVERY adjustment you make. I 'hosed' with my bleed and throttle-stop screw out of necessity - and as Grady said, you can get into no-man's land with the settings if you dont watch it.
I found that if my bleed was out more than about 2 turns, I had a simulated vacuum leak (hanging idle, etc). So I ran it out to the verge of that and forgot about it. Then I used needlenose pliers to mess with the throttle stop screw.
We all know Grady is smarter than I am, but I personally dont see an issue with playing with the TS screw if you WRITE down what you did since you can go back to square one if needed. I put a scribe in mine to locate "12 o'clock" and only made adjustments to the nearest 1/2 turn (I'd stop at 12 or 6 o'clock).
I also chose to make an adjustment and drive it a day. Then adjust again the next day. It took about 5 days to get it right. I dont feel you can get an honest read on how it will idle in just a couple mins (to incorporate how a rolling idle will be, high load idle with PS and brake lights working, etc).
We all do things differently so take what you will from each. And good luck!
D
Danman765432
471
Nutley, NJ
May 19, 2006
  • May 19, 2006
well i might need to change mine since my car after installing my cobra intake manifold is sitting at 650 rpms, which i believe is low but if it is not let me know
HISSIN50
34
129
May 19, 2006
  • May 19, 2006
Dan, that's a hair low for an AODE AFAIK (that is while in Drive, right?).
But if you dont have any voltage drop issues with a full electrical load, I personally wouldnt sweat it.
Just MHO. Good luck.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 19, 2006
  • May 19, 2006
The bleed screw can make your Stang idle really hokey, hurky jerky, or in other not desirable ways if you get it too far closed/open.
Using that little fast & nasty method above, here is something I might should'a said but took for granted it was understood.
Say you did not get a stable idle after the first pcm learning period.
Open or Close 1/4 of a turn
It don't make no never mind which way to start
If after the second pcm learning period ... it got worse ...
you went the wrong way
No biggy ... just turn it back the opposite way 1/4 of a turn and you are right back to where you started
Now go 1/4 trun more and see what happens.
Like Granpaw always said ... "Just common Horse Sense"
btw ... with this kinda thing, a pcm reset between adjustments is not needed IMHO.
Grady
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
Electrical Is this my throttle stop screw?
  • dqureshi06
  • Jun 7, 2024
3K
Fox 5.0 Mustang Tech Jun 14, 2024
dqureshi06
D
T
Fox 1993 FOX High Idle
  • TheJay806
  • Dec 24, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 15, 2025
Mustang5L5
K
2003 GT High Idle, vac leak process
  • krysber
  • May 11, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 11, 2025
krysber
K
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
