Hey, i was wondering how i take off my door panel so that i can try to fix the power window. It might tell me in my user's manual but i've lost that over the years.
CManT1914 said:http://forums.stangnet.com/showthread.php?t=334773
94/95 FAQ section, there's an article in there. Post #4. Pics and everything. I had to do this 4 times. Twice to "fix" the motors (driver's and passenger), then twice again to replace the motors when they went out again, lol.
). You just gotta pop it out.
. Ok, its been taken off at least once by my brother becaus he painted them, so the top part comes out extremely easy. It doesn't even really snap in at the top part of the switch panel but the bottom part by the sunk in spot (where u can put like... stuff in) feels like its really attatched.
Chythar said:There are a total of two screws and the one pushpin holding the door panel on. The two screws are already removed, they were behind the switch panel. And you've already removed the pushpin.
You also need to remove the cup around the handle, the one you use to open the door. It just pops out, though it can be difficult to get your fingers on an edge. Do you have the Mach 460 system? If so, you'll need to remove the top speaker. Pop off the grille, and there's a screw set in the one hole next to the speaker. If you don't have a speaker there, the triangular panel in its place just pops off.
Also remove the two screws behind the switch panel. You're right, it WILL get in the way when removing the door.
After that, if you lift on the bottom of the door panel, it should lift up and inch or so, then stop. then pull it out and away.
