gruvee87vertgt said:How do I tell the difference in 3.55 gears, 3.73 gears and 3.27 gears?
fiveofanatic said:Two are for pussies.
bynummustang said:How many times the string went around is the rear gear you have.
little less than 3= 2.73
Little over 3 = 3.27
About 3.5 = 3.55
Little less than 4 (3.73) =3.73
caseywan said:I've been told you just count the teeth on each of the gears and divide one by the other.
bynummustang said:Ah, what are you laughing at, you but lipped yank?
Well then. If he can't decipher what "3.73" stamped into a ring gear means, there's not much I can do.bynummustang said:He said the gears were on his floor, oh mighty ADMIN
fiveofanatic said:Well then. If he can't decipher what "3.73" stamped into a ring gear means, there's not much I can do.
Actually, in that case, I'm fairly impressed he was able to ask about it online.
