I never use the gap setting to adjust the pump, I just adjust the spring screw to where there's no gap, you want the pump arm to start moving immediately with the throttle shaft opening. You can adjust the length of the squirt with different pump cams, but that's not necessary in 99% of applications. For a bigger "shot" you can install a 50cc accelerator pump and different size squirter nozzles. this is really only needed with larger than stock intake plenums.
