I'm gonna be putting Caster/Camber plates on my car tommorrow and would like to know how to put them on and also how to adjust them accordingly. They are going on an 89 coupe. Any information would be greatly appreciated, thansk for your help....
Fox Saleen 163 said:..................... If you get stock alignment settings I will shoot you.
Fox Saleen 163 said:With a 1.5" drop you are pushing the bump steer problem and you will need C/C plates and probably a bump steer kit as well. You can probably do without both if you don't drive aggressively, but that's your decision.
I will never use stock aligment settings again, regardless of ride height. But, I drive like I'm at Indy.
, this car is going to be used for OPRR ( Open Road Racing) along with eating up a few ricers on the weekends.Matt90GT said:Oh, there is reason to replace the stock plates and use the stock settings!
It is how the strut it NOT located with the stock plates. The strut is located in a rubber donut. Thus it moves a lot. Just take the weight off the wheels with a stock plate and you can watch the top of the strut move up and down. imagine on the corners what that is like and how inconsistent your alignment is!
