How do you know if you have floating valves?
I was told that my valves may be floating cause I just installed them and didn't pressurize... pressur...pleasus..them, or something like that. Is it true? If so, how do I find out? I mean, a guy who knows about stangs helped me install them. We filled the cylinder with air and even turned the engine to block the valve with the piston. After that, we installed new 1.7s crane rockers, and that was it. Should I be worried?
Ok, but how do you know. Do you just feel it or what? Cause my car revs right on to 6500rpm with no problem. The first time I took it out after the tranny swap, I didn't notice right away, but I shifted right around 6800rpm and the car got there in no time. I know it's not safe and will place a rev limiter at 6400rpm.
I know guys. I didn't realized my rpm went up that high so fast. The tranny swap just threw me off. The car spun the tires so quick that by the time I turned to look at the rpms, it was already at 6800. I've haven't let go up that high since then. I need to go to the dyno to know where I need to shift. But yeah, a rev limiter at 6400 is coming.
