  • SN95 4.6L Mustang Tech
How do you replace O/D switch?
  • Thread starter Thread starter 96LaserRedGTS
  • Start date Start date Apr 9, 2005
9
96LaserRedGTS
47
Humboldt County CA
Apr 9, 2005
  • Apr 9, 2005
I have a '96 GT automatic with a failed O/D button. The overdive switch is next to the shifter. I pulled the plastic thingy surrounding it, but don't know how to get to the button itself.
Anybody know how? Is it easy to replace? Should I start looking for a mechanic? LOL!
I have the part already.
Help!!
Thank you.
Cindy
9
96LaserRedGTS
47
Humboldt County CA
Apr 9, 2005
  • Apr 9, 2005
Already searched
Oh, forgot to add that I have searched high and low on Stangnet and the Internet. I can't find ANYTHING about replacing the button, just what the O/D is supposed to do! I know THAT.
Help!!!!!!!!!!!! Please!!!!!!!!!!!!!
9
96LaserRedGTS
47
Humboldt County CA
Apr 9, 2005
  • Apr 9, 2005
Bump it up!
C
ceyko
54
  • Apr 9, 2005
Got pics? Is it like the '03's shifter?
9
96LaserRedGTS
47
Humboldt County CA
Apr 9, 2005
  • Apr 9, 2005
What are you talking about? I didn't replace the shifter. My O/D button has failed. I need to replace it.
Cindy
C
ceyko
54
  • Apr 9, 2005
Cindy
Obviously it is not like the 03 then. You might want to try going to autozone or something and looking through one of the Chilton/Haynes manuals. They'll have what you are looking for in detail.
Take care,
Ceyko
U
UhadMEatGT
117
  • Apr 10, 2005
I think MGW and some other places sell aftermarket shifter for auto's. When you put the aftermarket on, they sell an adapter kit that moves the button below the shifter handle since it wont be inside the handle anymore. I am sure they could help. I would guess you just have to take your handle off and pop it out, but the wires or plug in may actually be under your center console, Im not sure?? Also go by the Ford parts counter and have them pull up the picture that has the breakdown of your shifter, that should give you an idea of what you will need to do.
9
96LaserRedGTS
47
Humboldt County CA
Apr 10, 2005
  • Apr 10, 2005
Take care,
Ceyko
Chilton's? Did you say Chilton's? HA! Oh I looked in my Chilton's and can't find ONE SINGLE mention of an O/D switch! Worthless book, IMO. Maybe I'm not looking in the right section. If so, it seems to be hidden.
Maybe I'll try Haynes.
The button is on the plate, right, next to the shifter. I can't figure out how to get the plate off, or if I should even try. I'm not very mechanically inclined. After this O/D switch fiasco, I'm going to try to figure out how to replace the sensor that makes that pesky CEL go off. That looks simpler than this switch stuff.
Cindy
9
96LaserRedGTS
47
Humboldt County CA
Apr 10, 2005
  • Apr 10, 2005
Well I already have an MGW shifter handle that I installed a couple years ago, so I don't need another one. I just want to replace the bad O/D button that is next to the shifter. I'm tired of my car up shifting to 4th gear constantly in town. My button isn't ON the shifter handle itself. It's on the plate, next to the shifter, where you see the P R D 2 1.
I just can't believe there is NO information at all on the internet. Geesh, I've searched for every possible combination of terms and can't come up with anything except how the O/D functions.
Thanks for the Ford idea, though. Those parts guys don't really leave me with a feeling of utmost confidence, if you know what I mean, but they must have some sort of diagram, huh?
Cindy
9
96LaserRedGTS
47
Humboldt County CA
Apr 11, 2005
#10
  • Apr 11, 2005
  • #10
Ttt! :d
propellerhead
1,541
"but what's with the but shots?"
Apr 11, 2005
#11
  • Apr 11, 2005
  • #11
Have you looked in the Service Manual?
Yoda
Mmm...backwards, talk I.
2,046
Dagobah
Apr 11, 2005
#12
  • Apr 11, 2005
  • #12
Cant help you with getting the switch out of the console but once it is out there are just 2 wires going to it. Snip those wires and splice them to the new switch and reinstall the switch in the console.
GT-03
630
#13
  • Apr 11, 2005
  • #13
By the "plastic thingy" do you mean the shifter bezel, which would include the cigarette lighter too?
nyuk98gt
1,427
Chesterfield, MO
Apr 11, 2005
#14
  • Apr 11, 2005
  • #14
96LaserRedGTS:
You have removed the bezel (good). There are four bolts that hold down the shifter assembly. Be careful when you remove them because the nuts are the "folded" type and will slide off easily, necessitating a trip under the car! You may want to have a magnetic pick-up in the other hand to grab the bolts once they are ready to come out. Once the bolts are out, you can move the assembly around a bit and enough to get your fingers underneath to get at the switch. You will need to find the connection point and then disconnect the button electrical lead. I do not know if the button is held on the shifter plate with a nut (not likely) or a clip (more likely) -- the '98s have the button in the handle. Use needlenose pliers to pull the clip off. Now you should be able to install the new switch. Tighten up those bolts just enough (and a little at a time) so that the plate is about 1/16" lower than the bezel. You will need to trial fit the bezel until you get the plate gap just right.
HTH,
Chris
9
96LaserRedGTS
47
Humboldt County CA
Apr 12, 2005
#15
  • Apr 12, 2005
  • #15
nyuk98gt said:
96LaserRedGTS:
HTH,
Chris
Hey Chris, thank you so much for your help...but unfortunately, it came too late. I relented and took the car to a shop to do the job.
But, the bolt thing on the shifter assembly... I didn't see any bolts on my '96???? If I had seen anything that looked like it would slide off, believe me I would have tried. I removed the bezel thing and it was just the shifter plate, no bolts.
The shop that installed the switch, said they had to go through the console to get to the connection point. No problem for me, just glad it's done. I've been neglecting that switch for over a year now. Only cost $50 to replace the switch and a sensor. Maybe that's too much, but was worth it to me.
Oh, maybe I should make a separate post for this tid bit since lots of people have this problem, but I also have the P1443 code/CEL and all that fun stuff. Well, the same shop replaced the little sensor that runs from the PCV, then code cleared and VOILA, no CEL anymore!! This was driving me crazy 'cause I cleaned the IAC, replaced the PCV and gas cap, but NOTHING could get rid of that light!!
Cindy
nyuk98gt
1,427
Chesterfield, MO
Apr 14, 2005
#16
  • Apr 14, 2005
  • #16
Cindy
Cindy:
The shifter plate (the black plastic 'shield' with the PRND21 window) sits on top of the shifter assembly. The shifter assembly has four connection points to the chassis. With the bezel off, you can peek inside the console and see the bolts -- they might be hiding under the carpet but they are there.
I'm glad you got your new button installed and the CEL cleared -- good as new.
Happy motoring!
Chris
M
  • mnky99
  • Sep 5, 2025
mnky99
M
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
9
Brakes Rear brakes feel stuck after replacing pads and rotors
  • 99stanggtvinx
  • Aug 31, 2024
SN95 4.6L Mustang Tech Sep 1, 2024
nickyb
W
Electrical Rocker switch on done/map light replacement?? 93 hatch
  • white_stang
  • Aug 11, 2023
Fox 5.0 Mustang Tech Aug 12, 2023
85GTStangGuy
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
