I am afraid that there are bigger problems here however. Last week I took the car out on the freeways....it ran hot on streets at about 20-30 mph average as I was expecting, but on the freeway it cooled down to MA of NORMAL.
Last night I decided to take it for a drive (I love this car since my daily driver is a sluggish SUV) on freeways expecting it to run cool....no luck it's overheating on freeways now as well
! This is with new radiator and thermostat. When I came back the temp needle was in red...and the fan was blowing...but apparently not helping much. I checked upper hose to see if there was any appreciable pressure...it was hot but pressure-wise not much different from when engine is cold..does this mean anything? I know this is a loaded post and I appreciate you guys reading this. I guess my questions are:
1. Does high-temp (Temp gauge reading past L of normal) resistance of 2660 (normal is 700-1000) indicate that sensor is bad?
2. Am I looking at a bad waterpump? I'm assuming that at freeway speeds, fan or no-fan the circulation should be adequate to cool the car. Since there is no pressure at upper rad-hose (as there was b4 I changed radiator) I'm assuming water is not circulating due to bad pump.
3. I plan to remove remove thermostat and disconnect the ECT and take the car on freeways again this weekend (this insures that fan is blowing and new 180* balanced mr.gasket thermostat is not restricting flow). If the car is overheating am I correct to assume the waterpump is a gonner?
4. When the needle on temp gauge is on MA of normal...what temp is this approximately? And when it's border-line red what is the temp then?
Thank you again for all your help
