I see that its not like a normal alarm, not that sensative, what i am asking is, do you basically have to break a window to get it to go off? just fmi thans
GreenMustangGt said:I see that its not like a normal alarm, not that sensative, what i am asking is, do you basically have to break a window to get it to go off? just fmi thans
GreenMustangGt said:oh....whell i saw a light on the dash that says theft.....i see now, so what the hell is that 2nd beep when you lock the doors from remote? my momz had a 96' exploror that when you locked the dors it armed am alarm
That's an aftermarket system, really, Ford rebranded it and made it an installable option. It's not integrated into the car like PATS is.robertdale said:My car came factory with a ford security system.
robertdale said:My car came factory with a ford security system. I have a led light that flashes on my cluster beside the rear defrost button. It serves as a button to turn the car into just a remote keyless entry or an ignition kill with alarm if I press it. It beeps once if I have the alarm off to tell me the doors are locked. It also beeps once when I unlock the doors. When I push the dash button it turns the alarm on and the car beeps twice when I press the lock to indicate the alarm is active. It also has a small box in the drivers kick panel that has a shock sensitive switch on it to adjust the level of shock before it goes off. Also the alarm kills the ignition when active. Came on the car from the factory!
Chopped Liver said:My car has this exact setup you're describing. I always thought it was installed by the previous owner, but it does say Ford on it. Does anyone else have this alarm option?
I have an Alarm from made by python with the pager. The thing is a peice of garbage, the remote has had to be replaced already. I have the motion sensor option because my car is a convertible. Well the motion sensor sets the alarm off every like 30 minutes even if no one is by the car. I hate it and dont recommend it.Car Nut said:Crimeguard (crutchfield) has a system with an optional pager that alerts you instantly if your alarm is triggered from a mile or two away with specific information (that's cool).
