  • SN95 4.6L Mustang Tech
How does this work?
  • Thread starter Thread starter DTNODYA
  • Start date Start date Mar 7, 2006
DTNODYA
831
  • Mar 7, 2006
I have had an electrical Auto Meter water temp. sensor for a long time now but have never installed it. About two years ago, I tried to tap into the intake where the stock 'temp sensor' not 'sender' is, and ended up stripping that nut. I have found a way to fix that though ...
What I am wondering is how a electrical water temp sender (autometer) actually works? I lost mine when I stripped the intake back in the day (probably threw it as far as I could) but I am tired of looking at a gauge that does nothing. I would like to fabricate a sender (they just look like a piece of brass). If anyone has any knowledge regarding how they work .. how about enlightening me..:SNSign:
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 7, 2006
  • Mar 7, 2006
call autometer and get a new sender. it would be way to hard for you to fab one up.
DTNODYA
831
  • Mar 7, 2006
Yeah, calling autometer for a new one was my first thought but my stepdad works with valves, regulators, etc.. and has a lot of spare fittings and such so I thought I'd try. I am still curious as to how it works though if anyone knows. Does the brass in the 'sender' just warm to the temp of the water and then the wire running to the guage acts as a thermometer? This isn't a big deal, I would just like to know how it works...
40oz
499
Minneapolis
Mar 7, 2006
  • Mar 7, 2006
usually, the sensor uses an electronic circuit that is sensitive to tepms. The gauge is typically just a voltage gauge calibrated to the sensor. So even if you fab up a sensor, it won't match the gauge's readings. You need to get the sensor that matches your gauge to have any hope of the thing being useful.
propellerhead
1,541
"but what's with the but shots?"
Mar 7, 2006
  • Mar 7, 2006
The sender is a thermistor, which is a resistor that changes its resistance when it reacts to temperatures. Feed it 12 volts and measure it, then map each resistance value to a temperature. Each manufacturer may use different thermistors so you generally cannot swap one for another. Because of how thermistors work, it it very important that you wire it in per the manufacturer's specs, or you could be adding resistance and getting a biased reading.
DTNODYA
831
  • Mar 7, 2006
Thanks, I get it.
I will order another one like svttech76 and 40oz mentioned. Just trying to get creative (and cheap lol) but the sender is cheap anyway. Thx for the info people.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
