I just bought an 86 Capri which is awesome except for the fact that the coolant system is gunked up BAD. Apparently, one of the previous owners used stopleak to bandaid a bad heater core. A subsequent owner replaced the heater core and rad(looks like water pump as well). The coolant itself looks great. Perfect color, and no obvious floaties, but when I pulled the temp sensor sending unit, the passage in the intake was SERIOUSLy gummed up with crap. Do you think one or two sessions with an industrial power flusher will fix my problems, or will I have to tear the engine down and scrape/flush the heads, block, intake etc, separately?
Thanks
PS, the temp gauge seems to pick a different spot to hang out at each time I drive the car, but I think that is due largely to so much gunk around the temp sensor itself affecting coolant flow past it. It also intermitently looses heat (ie. blows cold air)The car runs awesome, and doesnt boil over, ping, or miss. Oil is clean, not loosing coolant, no white smoke.
Thanks
