needless to say im having traction issues. i need to take steps at this point to better the situation. i know i have to step up the tire situation. so i will prob go with one of the drag radial tires most likely nitto for the street use as its a street car.
my question is how else can i get this type of hp to the ground better. im aware that some suspension stuff can help but what suspension mods exactly? i dont have anything done to the suspension yet. i understand that dropping the car will only make it worse but i have to lower it a bit.
if i do manage to get some of this power to the ground, will the stock trans hold up or will i be getting that replaced soon after. i was thinking a pro motion built stocker....or a auto.
if i were to do an auto, what is reccommended and what all has to be done to support that transaction? im a manual trans now!
Problem: no traction in first or second even if i roll into it and then floor it. no traction in the top of 3rd after 5000rpm.
help me out guys....need to use some of this power! thanks
Panhard bar... sub frames maybe...
) should help significantly.
