How fast are you???
2MFF-Z28 said:
You think a c5 is that much faster than an fbod? VERY close in performance with the edge going to the c5 because of less weight. You do realize that they have the SAME motor right?
A car that traps 100mph stock is usually REAL close to one that traps 6-8 mph faster, your right, I get it now.
:hail2: LS1 :hail2:
Thats exactly why I said a stock fbod cant run or beat a c5 corvette because the vette is lighter and I am not sure but I would think they have better traction
Plus since when tdo fbods have 350 hp? I know they are underrated by I mean 350 is a bit of a stretch isnt it?
Vette LS1 = F-Body LS1 :nice:
Well, an 01-02 6 speed will put down over 300 rwhp EASY.
factor in a 15% driveline loss and you have 345hp
That is for 300rwhp most will put down over 310rwhp
Do you see the light?
These numbers could even be a bit conservative.
as stated above :hail2: LS1 :hail2:
Care to prove that? I admit I dont know much about fbods and corevettes but it doesn't make any sense for GM to make them equal in performance
It would be like if the new cobra is just as fast as the ford gt
the engines are similar but the cobra wont be putting up the same times
Plus, 15% loss determining factor is just a generalization
Have you ever seen the numbers for what the engine actually does put out? (not to the wheels, from the crank)
GM didn't make them equal in performance...1/4 mile will be close but everything else goes to the Corvette. They also rated the Z28 40hp less than the Vette and the SS 25hp less. I dunno if it was intentional or not...but fact is the LS1 F-bodies and LS1 Corvettes made very similar hp/tq...at least it wasn't even close to the 25-40hp difference that GM claimed.
*It's not really uncommon to see an LS1 F-body put down more rwhp/tq than a Vette due to the Corvette having a transaxle and IRS.
When my '99 Z was bone stock with less than 1000 mi. on it I ran consistant 104 mph with ET from 13.5-13.80 in mid 70 degree weather. Years later with a cat-back/ CAI/ predator tune/ no cats I got down to 12.9-13.0's at 108-109 mph in warmer weather. I suck at powershifting so all runs were granny-shifted. Evan Smith from MM&FF would probably go quicker. I sold the Z to my dad to order my '06 GT. We have a grudge race scheduled this fall IF I get it by the time the track closes. I am going to get a predator and CAI before I race him so it will be more fair. I assume the GT will run close to the camaro times with the tune and better than my stock times. He too conservative to powershift either so we will be using the same driving style. Both cars are awesome. I read magazine test for amusement and not much else. The camaro is on hiatus/the GTO is gaudy/the vette is expensive/and ricers suck so just enjoy your GT and dont worry about it.
This is correct..........sorry haters!
There is more to performance than straight line, but in that case the cars are REAL close.
The GT is a real sweet car, but to say it is equal in performance is silly. Now do some mods and your right there, but stock its just not going to happen.
Well I agree the 05 gt isn't as fast as the fbod but I still doubt that, that car can see 12's stock
Klay said:
I'm with peon here, doc just said he knows guys with some bolt ons and drag radials who get into the 12's but then others are trying to say they can run 12's stock? I mean come on, there is no way an ls1 camaro will run with a c5 vette which resides in the 12's
Also, a stock 03 cobra runs high 12's from what I have seen, you trying to say an fbod can run with them?
Klay, I said I have friends in STOCK fbodies in the high 12s. The solid axle is easier to launch then the IRS on the Vette. The LS1s in the 01-02 fbodies is the same as the Vettes with exception to the vettes throttle by wire. GM didn't want to step on the vette division's toes by saying the fbodies had the same power, but they did.
If you're an Fbody fan it is just FACT. You want proof go and join an Fbody forum and ask, they will tell you the same thing though.
It was an impressive bit of marketing, by GM. Produce ONE engine and simple rate it lower in the cheaper cars. This was a lot cheaper than producing TWO different engines. (There where changes but not to output) ALL LS1's regardless of what its in will should be and will be producing in the region of 345-350bhp. A typical Fbody will dyno 290-310rwhp, exactly the same as the Vette.
So as I've said before, you may not like this, but it is the truth. So you can either except it, or just rely on pig headed ignorance to see you through.
Do remember, although an LS1 is more powerful and has the capability to be faster, they won't every single time. The driver is always 50% of the equation.
peonslayer said:
Maybe I should quote the Stang that ran 13.35. Well I don't, because it was driven by a professional driver.
Go ahead and quote it brudda, I saw the vid, it was awsome. You do realize that the car had the ac removed, jack and spare, and the front sway bar, maybe more.
So your saying a car with 260-270rwhp can go 13.3, but a car with 300-310 rwhp CANT go 12's. That is silly, silly, silly. Read what you wrote and think about it. :bang:
I'd bet if a mustang with 300-310 rwhp went 12's you would believe it. I am the internet car forum optometrist and what you have is called myopia (tunnel vision). All you see is mustangs doing good things.
My painties are never in a bind, I think you'd have your a$$ handed to you by most of the 03/04's by me. Mine may not be one of them as it is on the weak side with ony 550hp, no sarcasm there just fact (most guys I know are into the 600+ range with plenty of mods to get it to the ground). So if you posted something, I may not think your full of it, I doubt you did though or you would have referenced it so for now, I still think your trolling.
The only point that matters is the Mustang is still around and the Camaro is not, this stupid argument goes from thread to thread. 10 years from now when all the kids have wrecked their rusty Camaros, this may go away. Ford did not design the Mustang to beat the Camaro in a race, they designed it to beat it in sales and the 05 owners need to realize and embrace that fact. It doesn't freakin' matter. You bought the car to drive and enjoy don't let the jackasses in the world take that enjoyment from you.
Look at those guys in the slow MG's and TR7's driving on the weekends with the big grins on their face. They could give a sh$$$$$$$t whose car is faster they just want to drive. Let's follow their lead.
The f-bods had the same horsepower as a Corvette? I guess this explains explains why when I raced a Corvette in my Z28 he pulled me hard. It never appeared the cars were equal for a second. I don't think they are that much lighter.
Is this how you justify mustangs being slow? :D j/k
Well rereading what you said I just misunderstood it, for that I'm sorry
I never doubted that the camaro is faster than the 05 stang I just doubt it can hit 12's
and generally, if you guys want people to believe the car can hit 12's and has 310 rwhp then you need to back it up with proof
Its not my job to go out and look for it
On a side note, I am not a mustang guy since I have yet to own one (I have an 06 on order though)
I mean I personally like the camaro and was debating on getting one before I saw the 05 stang but I am not going to believe the car hits 12's until someone can provide a timeslip or possibly a dyno showing that the car does indeed have 310 rwhp
