How Hard Is It To Bend Brake Lines?
  • Thread starter Thread starter smokin joe
  • Start date Start date Feb 10, 2016
smokin joe
746
45
49
Dallas,TX
Feb 10, 2016
  • Feb 10, 2016
I recently bought a complete 97 Cobra rear end and it has no brake lines on it. So what I need to know is:
1. How hard is it to bend my own brake lines?
2. How do I attach the brake lines to it?
Joe
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Feb 11, 2016
  • Feb 11, 2016
It's not hard to do brake lines. Go to the auto parts store get a cheap bender (although you may not need it) and a cut and flare kit.
It's easy to attach, there should be little clips across the top of the axle tubes.
Make sure to take the soft lines with you so you buy the right fittings.
Watch some youtube videos on cutting and flaring.
CarMichael Angelo
8,909
234
Birmingham, al
Feb 11, 2016
  • Feb 11, 2016
Joe
Simple stuff. Get the good bender ( you'll have it for life) a small tubing cutter, and a double flare kit.
* Insider tips
After you cut the tube off, get a cordless drill with the appropriate sized bit and run the bit into the end of the tube you just cut off. The bit will in effect ream the burrs off of the cut end, and insure that there aren't any raggedy fragments inside.
Get the two piece, articulated tubing bender for brake lines. Practice on a scrap piece and place a mark at the start of the bend and see how much the bend took away/ added to your length ( only important if you're gonna get all anal about perfect structure)
When you seat the little pin into the tube to begin the first bubble part of the flare, be sure you square it on top of the cut, and check to make sure it stays that way as you compress the the thing. If it gets cocked sometimes it'll break the pin, or it'll just be a pain in the ass to remove. Also, a cocked bubble will make a wonky second taper flare.
Don't forget to put the end on the tube before you flare it.
See,....easy.
Reactions: Noobz347
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Feb 11, 2016
  • Feb 11, 2016
This guy is even older than me. He knooooooooows....
BMW Rider
Mustang Master
Oct 9, 2014
140
277
83
Calgary, AB, Canada
Feb 11, 2016
  • Feb 11, 2016
The actual bending is easy with a good tubing bender, You can also get bending pliers which will allow you to make much tighter bends when needed in tight spots or close to the end of the tube. The tricky part of making your own lines is figuring out where to bent to get the best fit. I prefer to buy a roll of tubing and the nuts separately to make my own rather than modifying the pre-made lines. Tubing is pretty cheap and you'll have extra tubing to work with if you bend one wrong. Its usually easier to start over than try to straighten and re-bend. I usually get the line bent to fit with an inch or two of extra length at each end, then trim and flare the ends last, though sometimes you need to make a final bend at the end last if it is too close to the flare leaving you with not enough straight tube to clamp in the tool.
It was mentioned that you should deburr the end of the tube before flaring, for best results with a double flare, you should do both the inside and outside of the end. A tubing cutter works by displacing the metal and always leaves a raised ridge around the tube which will affect the quality of the flare produced if not removed. Usually if you are getting misshaped flares, it is because of the burr on the outside of the tube.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Feb 11, 2016
  • Feb 11, 2016
bending it is easy... flaring it on the other hand can be a bitch from time to time.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Feb 11, 2016
  • Feb 11, 2016
Like said before. Bending is easy. Flaring is the PITA.
Invest in a GOOD flaring kit. A cheap one from harbor freight won't cut the mustard
Reactions: jrichker
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Feb 11, 2016
  • Feb 11, 2016
See,....easy.
This is a lesson that may have to be learned more than once. I've forgotten to put fittings on and even put 2 fittings on by accident. If I liked my pick up truck more I probably would have take the extra one off, but it's a dodge so it's still on there.
srtthis
5,129
1,666
204
Maryland
Feb 11, 2016
  • Feb 11, 2016
and make sure they are the right direction also...
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Feb 11, 2016
#10
  • Feb 11, 2016
  • #10
All good advice. I did several lines on my car. The drill bit idea works well. In addition, I used a file to make sure my cuts were flat before using the bit. As stated abkve, YouTube is your friend.
Joe
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Feb 11, 2016
#11
  • Feb 11, 2016
  • #11
Find out if she can make smamichez before you marry her.
smokin joe
746
45
49
Dallas,TX
Feb 11, 2016
#12
  • Feb 11, 2016
  • #12
Thank you everyone for the advice. I'll give it a try.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Feb 11, 2016
#13
  • Feb 11, 2016
  • #13
You got to stick it in your mouth. I have never had luck with tube benders, always just did it with a pair of wrenches. Before you bend, stick it in your mouth and blow through it. Then blow through it again after you bend, and use your lung calibration to determine if you have bent in a restriction.
Kurt
stykthyn
5,232
2,652
223
gainesville
Feb 11, 2016
#14
  • Feb 11, 2016
  • #14
Kurt
So much material to run with here....
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
How to Route Subframe-Style Intermediate Brake Line?
  • cnorman31
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 29, 2025
cnorman31
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Fox Cobra wheels real vs. replicas
  • keel
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 8:52 AM
AeroCoupe
