How is this setup going lean?
  • Thread starter Thread starter DarkMesa8
  • Start date Start date Oct 25, 2004
DarkMesa8
1,087
Orlando, FL
Oct 25, 2004
  • Oct 25, 2004
My car is a 95GT vert, Edelbrock heads, ported Cobra intake, crane 2031 w/ 1.7RR's, full exhaust, tons of other bolt ons.
30lb injectors, brand new Kirban AFPR, Walbro 255lph pump, new fuel filter.
At 35psi, it was running at 16:1 A/F ratio! It took 47psi at idle, with no vacuum, to get even close to 13.5 ratio. That's 30lb injectors on an N/A 302! There was definitely a power gain when I got it at 13.5:1.
What the heck is up with that? It idled between 14-15:1, is that normal? When I would let off the gas, it would go rich at 12:1.
I always thought my car was running rich, from the exhaust smell and its pigginess under 3000rpms. Plus the fact that it backfired after idling forever. When I got my AFPR, I dropped the fuel pressure from 40psi to 35psi and could've sworn I gained power.
I recalibrated the brand new LM1 a second time just to make sure. Same results.
Why do I need 47psi to get a desireable A/F mix with 30lb injectors?
Rick 91GT
Mustang Master
95
99
PA
Oct 25, 2004
  • Oct 25, 2004
I had the same issue with a 30# inj on my old 302 set-up, ,made 340RWHP and was almost out of injector at 43psi (over 90% duty cycle at 6400rpm)
I know from expierence with a 2031 that the power usually dies by 5800rpm. What MAF are you running?
DarkMesa8
1,087
Orlando, FL
Oct 25, 2004
  • Oct 25, 2004
I'm running the Pro-M 75mm Bullet calibrated for the 30's.
Did you have a power adder when you needed that fuel pressure? What was your 302 setup?
Rick 91GT
Mustang Master
95
99
PA
Oct 25, 2004
  • Oct 25, 2004
NA 11.80 @ 116
http://www.cardomain.com/memberpage/215816/6
DarkMesa8
1,087
Orlando, FL
Oct 25, 2004
  • Oct 25, 2004
Damn, that motor sounds like a big breather. My 302 combo shouldn't need the fuel that yours did... any thoughts as to why it needs so much pressure?
DarkMesa8
1,087
Orlando, FL
Oct 25, 2004
  • Oct 25, 2004
Somebody just told me that the Pro-M 75mm Bullet is a piece of crap... could that be the cause? I've always been a Pro-M fan.
A
autoXr1
1,838
Michigan
Oct 25, 2004
  • Oct 25, 2004
You cannot run a car with 30# injectors and a 30# "calibrated" MAF with the stock 19# EEC fuel/timing maps without some drivability, AFR, and/or power output issues. Plain and simple. You MUST have the EEC's fuel/timing curves remapped due to your 36.33% load error on your combo. The '94-95 EECs run off a load table almost all the time and can be a bit more "finicky" than the '88-93 mass air EECs.
http://www.mustangworks.com/articles/electronics/InductionBlues.html Check this out. It should explain things in more detail.
DarkMesa8
1,087
Orlando, FL
Oct 25, 2004
  • Oct 25, 2004
So you're basically saying I'd better get off my butt and actually start using the TwEECer that's sitting on my desk, now that the wideband O2 is installed?
A
autoXr1
1,838
Michigan
Oct 25, 2004
  • Oct 25, 2004
IndyBlk5.0
1,122
New Whiteland, IN
Oct 25, 2004
#10
  • Oct 25, 2004
  • #10
LOL, who told you that? ROFL
DarkMesa8
1,087
Orlando, FL
Oct 25, 2004
#11
  • Oct 25, 2004
  • #11
http://www.corral.net/forums/showthread.php?p=4080913#post4080913
IndyBlk5.0
1,122
New Whiteland, IN
Oct 25, 2004
#12
  • Oct 25, 2004
  • #12
posted.
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
O
Computer swap
  • Oakman
  • Jun 22, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 22, 2024
Oakman
O
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
2K
Other Auto Tech Jun 24, 2024
Wallyman
