How Many Degrees Is A Tooth?
  • Thread starter Thread starter GREYFOX4INCH
  • Start date Start date May 12, 2005
G
GREYFOX4INCH
190
western MA
May 12, 2005
  • May 12, 2005
I Was Running 12* Timeing Pinging At 3/4 Throttle.
Retarded It All The Way To 8* Before It Was Ping Free
And 2 More For N20, I Am Currently Running 6* Timeing
The Motor Was Built By The Prev Owner
It Is A 306 With A Federal Mogul Cam With Non-ho 302 Fireing Order
Not 351 Order, His Reason For This.....who The F** Knows.
& Speed Pro Pistons
Ran The Juice With 6* With No Probs
But Today I Was Going Up A Hill And Had The Car Slowly Climing Rpm's, At Around 4000 I Decked It And It Detonated Violently.
I Had The Sterio On But It Didnt Sound Good. The Plugs Are New And
Two Degrees Colder Then Stock
Is My Distributor Be Off A Tooth?????
If It Is One Tooth Advanced And I Am At 6* What Is My Timing For Real, How Many * Is A Tooth? These Probs Suck Ass
Is It Internal?? Stretched Rod?
I Wanna Scrap The Motor But Cant Realy Offord It, And Im Scared To Wreck A New Motor If The Pinging Dosent Stop
Currently Trying To Solve Rich Mixture Prob On Diff Thread
Cyl#2 Turns Plugs Black Im Screwd
87mustang347
82
  • May 12, 2005
lol. w/o reading the whole post im goin to tell u right now. there is no such thing as beeing a tooth off. its obviose that the timing is off and u need to fix it and dont worry about the teeth on the ditributor gear
M
mikeflys1
217
CT
May 12, 2005
  • May 12, 2005
Just a dumb question....with that cam having the non-HO firing order did you re-arrange the plug wires to match?
G
GREYFOX4INCH
190
western MA
May 15, 2005
  • May 15, 2005
yes the fireing order is correct. and when you say the timing is off you mean, the chain or what? cuz the dist cant be accurate. ???
W
whitenblu89
70
westland mi
May 15, 2005
  • May 15, 2005
the distributor teeth dont really matter if you are pulling a 6* reading you are at six degrees.
HISSIN50
34
129
May 15, 2005
  • May 15, 2005
exactly. said another way, if there was nothing around the dizzy (interferance), you could install the dizzy any way you wanted and would simply have to rotate it till it was in time. when people incorrectly refer to being off a tooth, generally they mean that they cannot rotate the dizzy enough to get the timing they desire (because the TFI is hitting the t-stat housing, etc).
if it is in time, it is in time.
good luck.
G
GREYFOX4INCH
190
western MA
May 16, 2005
  • May 16, 2005
I Understatnd What Your Saying But The Question Remains
Why Would A Car With Minimal Mods Ping At 6* Most People Run 10-14* Dont They?
HISSIN50
34
129
May 16, 2005
  • May 16, 2005
a slipped outer ring on a balancer can allow one to run the wrong timing, causing detonation. there are many other causes (lack of FP, EGR malfunction, weak coil, too high a C.R. for the octane used, running too hot coolant-wise, hot intake charge, and many more).
good luck.
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
May 16, 2005
  • May 16, 2005
good luck.
Im with Hissin. My balancer spun on me and was off by almost 7 deg. Lucky I wasent trying to adjust the timing my buddy just happened to notice the wobbling.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
May 17, 2005
#10
  • May 17, 2005
  • #10
Count the number of teeth on a distributor drive gear - divide 360° by the number of teeth and youhave your answer. Anybody got a distributor handy?
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
May 17, 2005
#11
  • May 17, 2005
  • #11
I cant see how being a tooth off would make any difference...
You'd turn the distributor anyway to set the timing and the only side effect I can see is the TFI module smacking the side of the t-stat elbow as you went to rotate it.
I think the car will actually run with a 180 flipped distributor. I say "run" in the loosest sense. It will just about cough and stutter but it will run a bit. I learned that the hard way.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
May 17, 2005
#12
  • May 17, 2005
  • #12
THAT is what one tooth off means - where the TFI module winds up in relation to the factory position.
HardmanGT
500
Thomaston, CT
May 17, 2005
#13
  • May 17, 2005
  • #13
360 degrees divided by the number of teeth = degree per tooth
not that it matters
G
GREYFOX4INCH
190
western MA
May 17, 2005
#14
  • May 17, 2005
  • #14
YOUR MATH IS SIMPLE YET EFFECTIVE WHY DIDNT I THINK OF THAT. NOT THAT IT MATTERS AS YOU SAID.
THE TFI MODUAL HAS NO INTERFERANCE IN ANY OF THE TIMING RANGES THAT I MAY DESIRE 4-20. IM GUESSING BY THE ENLESS LIST OF REASONS THAT CAN CAUSE DETONATION, ITS NOT EVEN THE DAMN TIMING
ANYONE WANT TO BUY MY PIECE OF ****????
10 GRAND LOL
BUY THE WAY THE STARTER WOULD NOT SHUT OFF WHEN I STARTED THE CAR THE OTHER DAY WITH KEY ON AND OFF, 2ND STARTER I HAVE BLOWN
I JUST PULLED OUT ONTO THE STREET AND HELD IT TO THE WOOD I WAS SO PISSED. I SMOKED THAT THING PRETTY QUICK. MADE SOME GREAT NOISES. (I DIDNT WANNA HAVE IT TOWED)
I JUST HOPE THE PARTS COMPANYS ARE SMART ENOUGH TO MAKE THE STARTER DRIVE GEAR WEAKER THEN THE FLYWHEEL,BUY THE LOOKS OF IT I THINK SO. ILL HAVE TO SEE HOW THE FLYWHEEL LOOKS WHEN I PULL THE STARTER.I DONT WANNA EVEN LOOK AT THE CAR RIGHT NOW.MAYBE SAT
MY IGNITION JUST BROKE TOO SO YOU DONT NEED A KEY TO START IT
BUT THE STARTER PROBS PRECEEDED THIS OCCURANCE
MAYBE I SHOULD JUST GET HYPNOTIZED INTO BEING AUTO MOTIVE ILLITERATE
AND DRIVE A CAVALIER
T
  • Locked
Expired 2001 Mustang Gt Stroker/blown
  • tremainb
  • Sep 2, 2015
2K
SN95 Mustangs For Sale (1994-04) Sep 2, 2015
tremainb
T
  • Poll Poll
5.4l Dohc Swap
  • TeamCaffeineGT
  • Aug 26, 2014
51K
1996 - 2004 SN95 Mustang -General/Talk- Nov 1, 2021
TeamCaffeineGT
94 GT pinging, help please
  • Canary94GT
  • Aug 29, 2011
  • 1994 - 1995 Specific Tech
  • 2 3 4
12K
1994 - 1995 Specific Tech May 11, 2025
General karthief
Project "true Blues"
  • 1lugloose
  • Jun 22, 2012
  • SN95 4.6L Mustang Tech
  • 2 3
5K
SN95 4.6L Mustang Tech Aug 30, 2012
Kilgore Trout
K
The rematch (Or how I learned about nitrous....The hard way) only 1 left!
  • CarMichael Angelo
  • Jun 29, 2011
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2011
CarMichael Angelo
