how many qt's of ATF to fill 95 T5
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
how many qt's of ATF is it gonna take to fill up my T5? i bought 3 but i read somewhere the other night that it takes 4??
i can just pour the ATF right into the shifter area before i install the pro-50 correct? how do i know when its full?
To connect the dots with what John et al said. If filling through the shifter base:
Remove the fill plug first. As you fill through the shifter, keep an eye on the fill plug on the side of the trans. When fluid starts to come out the fill plug, the trans is full (assuming you are on level ground, etc).
Fox T5's take 2.7 qts, and I dont see how yours are different (though the input shaft is longer, the box is the same dimensionally, I would think).
Good luck.
