How Many Windsors in 70 Mach'S ?
Fomoco98
56
TN
I am restoring a 70 Mach H code with a windsor in it and one of my friends said they did not put many Windsor's in them because they changed to cleavland's . this may make a Diff how I do the job. Thanks Dave.
There allegedly were no 4v windsors on 1970 Mustangs. The Marti reports does not specify, they ony tell you the H code part, which you already know. I am pretty sure even Ford didn't know at the time.
Fomoco98, I used the Coast High Performance kit. It was a comedy of errors of mismatched parts, but we finally got it right. Uses forged Probe 302 Pistions, stock 351w rods and a chinese crank. The machine shop did the clearancing for me, but it wasn't real major. One problem I ran in to was a crank counterweight hit a piston boss, and we had to machine down the counterweight to clear. I inderstand that something like that is pretty unusual. I topped it off with an Edelbrock Performer RPM kit including the heads. I used the 1.90 intake heads as they flow about as well as the 2.02s due to shrouding, and I can throw them on another motor if I want without as many valve clearance problems. Crane gold full roller rockers, Hedman coated shorties and a 750 Holley sits on top. I did all the dissambly and cleaning myself, had the machine shop do all the machine works and I had them assemble the pistons, rods and crank for me as I am in a dusty envoronment, and I wanted then to be sure everything spun freely before I drove 75 miles to pick it up. That turned out to be a good call. I assembled the rest myself, including cam and valvetrain stuff.
