How much difference between a 302 and 306?
  • Thread starter Thread starter underdog225
  • Start date Start date Sep 25, 2007
U
underdog225
39
Minnetonka, Minnesota
Sep 25, 2007
  • Sep 25, 2007
Beside the obvious cube size difference, is there any big difference in peformance gains if the same parts are used?
ttop88
42
indiana
Sep 25, 2007
  • Sep 25, 2007
If it has the same pistons(comp) it would be the same power. The 306 would run a little hotter tho.
U
underdog225
39
Sep 25, 2007
  • Sep 25, 2007
So really no major reasons to bring a 302 to a 306 unless it has to be bored out because of bad sidewalls.
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Sep 25, 2007
  • Sep 25, 2007
it makes no diff in power really, its only 4 cubes. its just to freshen up the cylinder walls to start over with fresh metal.
Aliate X
602
Rockland NY
Sep 25, 2007
  • Sep 25, 2007
The average hci 302 makes a little over 1hp per cubic inch, so say 4hp. 306 is no different than a 302.
88-378
14
Alpharetta, GA
Sep 25, 2007
  • Sep 25, 2007
Sorry I had to.
Flavadave4
1,044
21
49
Utica, NY
Sep 25, 2007
  • Sep 25, 2007
LOL......beat me to it!
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Sep 25, 2007
  • Sep 25, 2007
you wearin that flame suit aliate?
88-378
14
Alpharetta, GA
Sep 25, 2007
  • Sep 25, 2007
:OT: I like your wheels. ROH ZS and the racing ZS are the nicest wheels on a fox!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 25, 2007
#10
  • Sep 25, 2007
  • #10
Boring it out provides fresh cylinder walls and increases compression slightly by increasing the sweeping volume.
My engine runs the same temp. (stock guage though) as it did before the rebuild.
Click the link in my signature for the differences between 302's and 306's in more detail under 302 Stroker Information.
If your looking at your old block, check and see if it has much of the stock crosshatching in the cylinder walls. A machine shop could just hone it out for you and you could reuse your old pistons! Crosshatching angle is important for oil retention on the cylinder walls, whether the engine is running or not. To steep of a crosshatching can cause more ring rotation and less oil retension on the side walls. Shallow crosshatching doesn't allow the rings to rotate enough to let go of excess heat and more blow-by can occur.
Aliate X
602
Rockland NY
Sep 25, 2007
#11
  • Sep 25, 2007
  • #11
88-378 said:
Sorry I had to.
lol...
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
H
Brand New Built 302 overheating
  • hassler
  • Sep 26, 2025
Rcdgl
R
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
