How much for spring install????
Should be about an hour worth of labor, if even that. I can be done in about 30 minutes. I would'nt pay more than one hour. Caster camber plates, 30-45 minutes. No more than 140.00 combined. Just me.
Took me and a friend 4 hours to do my car...taking our sweet time and using all hand tools. First time.
A friend of mine got a quote to do his GT convertable...about $450 for springs, install, and alignment. Three of us ended up doing his car in about 2.5 hours. Again, using nothing but hand tools. Cost, $195 for springs.
Just another guy chiming in to do it yourself. Borrow the spring compressor from Autozone and get a buddy. I did my Eibach set on my 01 vert by myself (you really should have 2 guys) in 4 to 5 hours and I'm no mechanic. Follow the above instruction link closely taking your time and it should be easy.
az_r2d1 said:
Good write-up. Looks like changing springs on IRS is even easier than on a solid axle model...
I say do it yourself.
Having done both on my car hands down GT is way easier. Unbolt the quad shock and lower shock bolt, lower a-arm, yank out spring. When I get new LCAs then the quads go bye and it's just 1 bolt.
On the IRS install it can be a PITA. I found it easier to lower the IRS vs. using a spring compressor. The first time I did it it took me about 8 hours by myself, half of that was spent trying to get the IRS back into alignment with the mounting holes. After that I got to where I could do it in a few hours.
Do it yourself! 2 Jacks and a spring compressor. Can do all 4 in an hour. The IRS isn't all that bad either. But if you wanna watch, don't pay more than an hour. I shopped around before I did um myself and most places wanted to charge $400+. It's easy money for them.
Sean
