how much hp do you think?
mustanglouie
152
Oakwood GA
I was wanting to know what yall thought about this combo.
302 with gt40p heads
E303 cam (came with motor)
trickflow street heat intake
70mm throttle body
73mm mass air for 24lbs injectors
cone filter
Mac 1 5/8 long tube headers
dr.gas x pipe
2 chamber 40s flows
and maybe soon 3.73 gears
How does that combo sound?
Thanks for the info in advance
Louie
70mm throttle body
cone filter
dr.gas x pipe
2 chamber 40s flows
Louie
would a chip help me out? If so were would I get one? I want this thing to run good with all the bolt on's that i have.
You could put half a dozen combos together that were the same and each one would not put up the same numbers. I would not be surpised to see as much as 15 - 20rwhp difference between the low & high values.
As for the tune ...... it could yield more on one of the lower power producing examples above. The opposite results the other way around.
Thats why ...... even though these "guess my dyno numbers" threads are fun and all.
You have to remember these guesses are just ball park numbers.
My guess would be :
untuned 255 - 265
tuned 265 - 275
hope you get 275 - 285 :banana:
Grady
