How much insulation do i need?
  • Thread starter Thread starter bad68coupe
  • Start date Start date Jan 23, 2007
bad68coupe
220
Richardson, TX
Jan 23, 2007
  • Jan 23, 2007
I am looking at insulations, think i am going with the damplifier pro, and I am wondering how many square feet i need. I plan on doing the entire inside of the car (firewall, floors, inside doors, trunk floor, inside quater panels, roof, everywhere) I thought that i heard that 160 square feet takes car of it. And i can go out and measure the space but i feel that that will be too much of a rough estimate. I want that Lexus, Mercedes, luxury car feel, where its like your in a sealed compartment. I also wouldn't mind if my door to make that same air tight thud when i close the door. So my question are:
How much do i need?
Should i put two layers of insulation on?
(I figure i can do a nicer insulation on bottom and then somehting like B-Quiet or FatMat on top, becuase there will be a significant temp difference between the points of adhesion.):SNSign:
BullittStangV8
1,104
NJ
Jan 23, 2007
  • Jan 23, 2007
I would ask in the audio section of stangnet. I went with just one layer for dynamat for my trunk in my '01, but 2 layers would have been better.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
