I'm planning on a 5.0 / T-5 swap in my '65 coupe fairly soon. The motor could use a rebuild but has given me almost a year of 100% reliable service since I bought the car. It smokes some and does have some blowby. Here is a detailed list of what would be included in the package:
1966 289 heads (not sure of specs)
1965 4100 carb (C5ZF stamped on base)
block #C5AE-6015E
gold valve covers and air cleaner assembly (can use a cleaning / repaint)
stock exhaust manifolds
distributer, cap, wires (I may even throw in the spark plugs)
A/C compressor in good working condition (blows very cold)
P/S pump
water pump
alternator (replaced two months ago w/lifetime warranty)
starter
all accessory brackets
3 speed manual transmission
bellhousing
all other clutch components including clutch linkage but not the pedals (clutch disc, pressure plate, and T/O bearing will need to be replaced)
stock fan
3 row radiator
I will be keeping the wiring harness, accelerator linkage, shifter, coil, A/C hoses, and P/S hoses. Other than that I can't think of anything else I want.
If there is any further research anybody can point me to do on these parts to determine their exact value, please let me know.
I'm a reasonable person and wouldn't be looking for a ton of money, but I do know that some of these parts are worth a few bucks (carb, p/s pump, bracketry, etc). I'd just be looking to get a fair price to help offset the cost of my current build.
Any input is greatly appreciated.
block #C5AE-6015E
P/S pump
water pump
starter
bellhousing
stock fan
3 row radiator
