How much lift can stock GT40P springs handle? Getting Cam, need to know!
astronut1885
1,899
Assonet, MA
Hey guys. I am going to get a new camshaft for my engine buildup, and I want to know if the springs on my new heads can handle it. I have a set of GT40P heads on their way to me. They have had enlarged (1.54") exhaust valves put in, and are brand new. I have no idea what springs are on them, but if they should be stock, how much lift can they handle? I am going to be using a Trick Flow stage 1 cam, with specs:
Specifications:
* Advertised duration: 275 intake/279 exhaust
* Duration at .050 in. lift: 221 intake/225 exhaust
* Gross valve lift: .499 in. intake/.510 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 2,000 to 5,500
Any help is greatly appreciated.
Thanks! :spot:
spring works
astronut1885 said:
I don't know if this helps, but those springs should be just fine for that advertised lift if you use the 1.6 rockers. Some even run the 1.7's, but it is definately close depending on the pistons. Whatever, check this before you get too far. I ran FMS 1.72 rockers on the GT40 heads from an early Lightning with no problem, and this was stock pistons at first, then some TRW forged later.
Specifications:
Thanks! :spot:
They don't handle alot of lift. The gt-40 COBRA springs are the good ones. I have a set of cobra springs. They are good to .550 lift. They are in great shape. Just had them all checked and they all are in spec. I will sell them if you are interested.I have the locks and retainers also. Let me know.
You could use the stock springs but why put all that money into a motor and WAIT for it to let go. They are not that good of a spring. Just get a good set and be done with it.
Let me know if you want them.
Mike
I got the heads in today, and I don't think that the springs are stock. They have a coil inside the regular coil. Pics can be seen in the link in my sig, go to the last page. If anyone has any ideas what they are, let me know.
Thanks.
I am using the Ford SVO springs & retainers, and they work just great. I had them on my old E7's, then transfered them to my GT40P's. I was also running an "E" cam. Just take the springs to a machine shop, and have them pressure test them, to see if they can handled atleast a .500" lift.
Leo
