How Much Nitrous Can i run
  • Thread starter Thread starter JWadeSchutt
  • Start date Start date Apr 16, 2007
J
JWadeSchutt
27
  • Apr 16, 2007
I have a 1982 5.0 bored out, forged pistons, windage tray, chromoly rings, clevite bearings, lunati voodoo cam, stock heads, and i will be getting an edelbrock performer intake, and holley 650 carb. what would be the largest and safest shot that i could run and do you guys have suggestions on what kits to go with? thanks.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 16, 2007
  • Apr 16, 2007
Dual plane intakes have an issue with air volocity i believe. I have been told that with a dual plane intake it is not a good idea to run over a 150hp shot.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 16, 2007
  • Apr 16, 2007
go with a wet kit and jet it to a 100hp shot. the edelbrock kits and solinoids are very nice. High quality from what I have seen.
J
JWadeSchutt
27
  • Apr 16, 2007
if i went with a different intake would it be worth it and could i run more?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 16, 2007
  • Apr 16, 2007
I have a dual plane intake and I run a 150 shot. I have been told thats pretty much the max for a dual plane. If you want to run more juice then that yes you should be looking at a single plane intake. Now if you get a single plane itake remember that you are going to lose bottom end torque. A vic jr for instance starts making power at 3500rpm.
J
JWadeSchutt
27
  • Apr 26, 2007
ok thanks what kind of brands should i go for?
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Apr 26, 2007
  • Apr 26, 2007
Most of it will depend on ignition and making sure you have enough fuel VOLUME. Otherwise if all that is taken care of 150 should be fine.
32785stang
30
  • Apr 27, 2007
You also have to make sure that your ring gap is big enough to handle a big shot.....the more nos the more heat, the more heat the more the ring expands.....to much and the ring ends will touch =no good
stevesLX
373
cincinnati
Apr 27, 2007
  • Apr 27, 2007
Not to steal your thread or anything but I was wondering the same thing. I have a 89 LX with a stock 302 block pistons and crank. It is fuel injected with 24# injectors edelbrock performer 5.0 intake and F cam. I was given a Zex dry kit for this car that has a 75 100 and 125 shot. I was kinda curious how much I would be safe to spray. Ecspecially since my heads have really been milled on a lot as well as my deck height. Anotherwards my clearances are very close.
Flavadave4
1,044
21
49
Utica, NY
Apr 27, 2007
#10
  • Apr 27, 2007
  • #10
stock block and pistons i wouldn't go over 150
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 27, 2007
#11
  • Apr 27, 2007
  • #11
persoanlly on a dry shot I would go more then 100hp.
Flavadave4
1,044
21
49
Utica, NY
Apr 27, 2007
#12
  • Apr 27, 2007
  • #12
Yeah i should have mentioned i was talking about a wet kit
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 27, 2007
#13
  • Apr 27, 2007
  • #13
Yah I'm sure it will go over 150hp shot with the right tune and supporting mods. But you are getting into the limits of the factory block hpwise. Your flirting with making the kinda power that will crack your block.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Yesterday at 6:45 AM
DadLife0724
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
