  • 1994 - 1995 Specific Tech
How much Nitrous on 1995
  • Thread starter Thread starter tbird187
  • Start date Start date Aug 24, 2004
T
tbird187
392
Indiana
Aug 24, 2004
  • Aug 24, 2004
Modding first 95 Gt, motor has 90k on it... Looking to put some juice on it to get it alittle faster... Can anyone recomend what size shot.... wet or dry... Full exhaust, and gears are the only mods, and a walbro 255 pump....
stang_gt_1994
2,723
Powder Springs, GA (30 min. from Atlanta)
Aug 24, 2004
  • Aug 24, 2004
I would say a 75-100 shot and get a wet kit.
Joes95GT
3,132
Delaware
Aug 24, 2004
  • Aug 24, 2004
If you're going to do it the right way and run colder plugs, less timing, and get it tuned on a dyno with a wideband, I'd say you could use a 150 shot. If you aren't, I wouldn't use anything above a 75.
Wet kits seem to be a bit safer, however, neither kit is idiot proof.
Joe
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 24, 2004
  • Aug 24, 2004
I'm with Joe -- do it right, and strap on a 150 NX kit.
94TURBO5 O
2,509
VA
Aug 24, 2004
  • Aug 24, 2004
I used a dry kit 100 shot from 129K to 148K going through 2 bottles a week and no mechanical problems ever when I ran it.
blueneonman
866
Robins AFB
Aug 24, 2004
  • Aug 24, 2004
I started out with a 75 dry shot on my car with about the same mods as you. No problems. Ran 2 heat range colder plugs and constantly checked them for detonation. So I upped the shot to 125. Still no problems, plugs were a bit more whiter, but soon after my tranny took a big hit. Try not to peg it off the rev limiter. I ussually hit it off the line after about 3-4k in 1st gear. Use the WOT switch.
Have fun! Later.
9
94DreamGT
593
Indiana
Aug 24, 2004
  • Aug 24, 2004
You'll want to get the GSS340 Walbro Hi-Pressure 255lph fuel pump. It is specially designed to handle the high-pressure requirements needed with N20, Supercharging...any forced induction application that requires loads of higher fuel.
G
green_drop
43
  • Aug 24, 2004
I had a similar setup I ran 10* base timing. I also had a 255 aeromtvie fuel pump a fuel pressure regulator and dynoed it to get the perfect air/fuel ratio then i ran a little rich. Ran a 150 NX wet shot for 2 years never had a problem. I would agree with hairy canary and get NX 150 wet shot with a WOT switch.
N
nathanralph
  • Aug 24, 2004
I'm usin' a 100shot dry kit on my relatively stock 95 GT. fuel pressure safety switch, WOT switch and RPM switch.
baglock1
The Bartender
6,612
Space Coast, FL
Aug 24, 2004
#10
  • Aug 24, 2004
  • #10
I say run a pair of 300 hp setups. One for each bank. When the bottom end evaporates, build a forced induction stroker.
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
W
Help with 95 GT
  • waynewl34
  • Apr 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 5, 2025
