How much power can the stock air box & air tube support?
wel if you got the stock intake and tube on with the setup you got then i would think so definetly. With h/c/i in you should really be starving your motor with the stock stuff. A CAI would bring it a 12.9 i think. just M.O.
even if the stock setup can support 400hp and your motor is stock by upgrading things you stand to gain. maybe small but the gain will always be there
and if I remember right intake setups are not that expensive and can also be home made if you so choose
........i doubt youll see a difference you can get a C&L or Pro-M mass air.........that would be better then the stock mass air but the airbox as long as you take the silencer out it should be bout the same....u can always get a powerpipe though =d
Well let me clearify....
I have the stock air box (silencer is long gone) a K&N panel filter & a Pro_M 75mm MAF... going to a 70mm t-body.
Is the stock plastic air box & plastic inlet elbow restricting anything???
