How much power do u think this combo would make ?
Turbo Ex
Hey man, heres a quick run down on the whole car. 95 mustang cobra
-306 balanced forgds pistons ( JE ) 9:1 with Forged I-Beam Rods
-TFS Twisted Wedge heads out of the box.
-TFS Track Heat intake manifold.
-Comp 274 Cam.
-Alum Flywheel.
-MSD 6AL and coil.
-Griffen ALUM radiator car runs about 185 deg with the ac blowing on
a hot day.
-Pro-M 77 mass air
-24 pound injectors.
-PMS EFI. (Incredible tuning capabilities... I love this system)
- 255 intank pump.
-Tremec 3550 5 SPD tranny with PRO 5.0 shifter.
-3.73 gears.
-Subframe connectors weld on type not the cheap bolt on crap.
-1 5/8 Ford Motor sport headers with a BBK X-pipe and 2.5 Flow Master cat back.
-New brakes
and what do u think it would run on some drag radials . just curious :)
It should do 315+ tuned. What kind of pistons are those and what makes you think your 9:1 compression? I hope you swapped the valve springs. That comp 274 is gonna cause some valve float up top on stock tfs springs. Was the cam degreed in or just thrown in dot to dot?
Im not quite sure what springs are in it yet the guys is supposed to be emailing me a list on all the stuff in the head's. Im sure the pistons are a off-the shelf 9:1 for a 5.0 motor. For the cam i dont know on that either im looking at buying the car but i just wana some feed back on the setup of it. But ill get the rest of the details and post them up.
Ok i talked to the guy some more and he said that the head's were bought complete from trick flow. he said he didnt assemble the motor it was done at a shop so im assuming that it was degree'd in.
