How much power/mileage difference
  • Thread starter Thread starter iowabowhunter
  • Start date Start date Jan 31, 2006
I
iowabowhunter
62
  • Jan 31, 2006
Hi
I have a drivetrain out of a '89 GT that I'm going to put into my '71 Maverick. I'm wanting to put a carb on it probably somthing like a Peformer RPM and a 600 edelbrock. How much mileage do you think I will loose and do you think there will be a power difference? I guess I'm not looking for a mpg number just an opinoin if you think the mileage difference between the efi and the carb would be noticable.
Thanks
Bob
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 31, 2006
  • Jan 31, 2006
Depends on the state of tune, and how the car is used. The more 'steady state' (highway) the driving pattern is, the less difference in fuel mileage there's likely to be. And getting the carb/timing curve set up correctly makes a BIG difference.
Why the swap to carb if you already have the efi drivetrain?
blackstangt
460
ny
Jan 31, 2006
  • Jan 31, 2006
yea, why not just use the computer and wires out of the fox, it would be impressive to see and efi(generalization) is more efficient than carb.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 31, 2006
  • Jan 31, 2006
Hmm, i wouldn't use a edelbroke carb.
Go with a 600 Demon, they're the cadillacs of
carbs in my opinion. easy, easy, easy to tune.
I
iowabowhunter
62
  • Feb 5, 2006
Well I kind of wanted to go with the carb set up cause I didn't know if I wanted the look of the EFI. But today I was going through a Summit and found an intake make by BBK called the SSI Series I think looks pretty cool so I may go the EFI route with one of these BBK intakes.
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
G
Drivetrain trickflow Stage 3 camshaft 347 stroker. also too much gear????
  • Gross Virgin
  • May 2, 2024
Fox 5.0 Mustang Tech May 2, 2024
Gross Virgin
G
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
