How much power?
MyHoFoSho
100
Hey guys i wanted to know what kind of hp and torque numbers i will see from my new engine. It is a mexican blocked 347 with all forged internals, with patriot perfomance 185cc heads with 11.1 comp, eblebrock cam .524 lift on intake and exhaust with 1.6rr, edlebrock performer rpm 2 intake, 70mm tb, 75mm maf, 24lbs injectors,and cai. I think that is all so i wanted to see what you guys think it would make just at the motor or if any thing will help out at all i am hoping for some good numbers. thanks
70mm TB seems a little small, as does the 24lbs injectors & the MAF. Are you building this or buying it complete?
347 Test Motor Specs
•Block - 2-bolt 5.0
•Crank - Cast 3.40-inch 347-Coast High Performance
•Rods - 5.40-in. Steel H-Beam- (CHP)
•Pistons - Forged 10.5:1 5.0 Probe (11.5:1 with milled heads)
•Cam - XE 292R (Comp Cams)
•Lift - .621 in, .627 ex (.016, .018 lash)
•Duration - 254 in, 260 ex
•Lobe Center - 110
•Heads - AFR 185 (CNC ported & milled)
•Valves - 2.02-in, 1.60-ex
•Rockers - Comp Cams 1.6 ratio roller
•Intake - GT-40
•Throttle Body - 70 mm Accufab MAF - 77mm ProM (36 lb. calibration)
•Computer - EEC IV plus Ford Racing Extender
•Injectors - 36 lbs.-hr.
•Ignition - MSDHeaders - 13/4-inch full length Hooker
•Water Pump - Electric CSI
•Timing - 34* Total
TEST 1 -- GT-40 Intake-Baseline
•Peak Power Numbers: GT-40 Intake CHP 347-AFR heads & XE292R cam
•Peak Horsepower-GT-40 450 hp @ 6600 rpm
•Peak Torque-GT-40 447 lbs.-ft. @ 4700 rpm
The heads you are useing are AFR185 knock offs. so this comparison should be close. Your flow and power numbers will most likely be lower. The intake you chose is in between the systemax and gt-40 so I will show both numbers.Only thing changed was intakes.
Holley SysteMax II
•Peak Power Numbers: GT-40 Intake vs. Holley SysteMax II
•CHP 347-AFR heads & XE292R cam
•Peak Horsepower-Holley 474 hp @ 6300 rpm
•Peak Torque-Holley 436 lbs.-ft. @ 5300 rpm
