how much power?
BAD STANG
14
i've got a '91 stock bottom end,E-303 cam,performer rpm air gap intake,1.7 ratio SVO roller rockers,mac equal length headers,msd 6-A and blaster 3 coil,underdrive pulleys,H-pipe,and a holley 650 double pumper carb.could anybody give me an estimate on hp?
you show 244 rear wheel,and you have no cam,and we've got the same heads,and i've probably got more fuel,or at least the potential for it.
My heads are ported/milled and are worth ~20rwhp more than the stock unported heads.
I have a 76mm MAF, 75mm TB, and a Performer intake that's been port-matched for the 75mm TB, so it should flow a lot more than 650cfm.
My headers are long tubes (more power than shorties) and I don't have cats.
Your E-cam will only produce slightly more HP than the stock cam when paired with the stock heads, and it'll produce less torque below ~3000rpm.
