Roush How much $ to have my 13" Saleen front bakes installed.....
Yeah any reputable place can do it. I wouldn't put it past pep boys to mess it up though.
It also makes for a fairly easy driveway project as well. Remove the stock calipers, caliper brackets, rotors, and lines. Put on the new rotors, then put on the calipers and torque to 90 ft. lbs., then put on the new lines and tighten them down, then just bleed the brakes and reinstall the wheels and you are done. The Brembo instructions are very clear and make for an easy install.
Yea,
Front brakes are super easy just like Acheron315 said. If you don't want to do it yourself any brake shop will install them for you as long as they are new. Should only charge you one hour labor. You are gonna love all the dust from those pads Brembo supplies. :D
If you don't like doing a project yourself, i suggest you find either a speed shop or independant mechanic that you trust.
Don't take it to any chain shop.
