kreymis Member May 27, 2009 93 0 7 peekskill, ny Aug 12, 2009 #1 Aug 12, 2009 #1 i have a 331 with s-trim. my vacuum gauge reads only 10 psi at idle. is that enough or is that right. i have an afm b31 cam.
toyman 10 Year Member Jul 19, 2007 1,944 54 79 Vernon BC Aug 13, 2009 #2 Aug 13, 2009 #2 kreymis said: i have a 331 with s-trim. my vacuum gauge reads only 10 psi at idle. is that enough or is that right. i have an afm b31 cam. Click to expand... Not 10 psi more likely 10 in-Hg. Mine with a comp 270HR cam reads about 12 in-Hg. Probably normal with the cam.
Black Stampede Founding Member Sep 3, 2002 1,811 2 39 Grand Rapids, MI Aug 14, 2009 #3 Aug 14, 2009 #3 Also will vary based on where your idle is set.
Grn92LX Fidanza Man! Founding Member Jan 14, 2001 6,819 64 129 New York Aug 14, 2009 #4 Aug 14, 2009 #4 call anderson and see what they say that cam should make. Sounds way low to me.
revhead347 Apparently my ex-husband made that mistake. 20+ Year Stangneter Jun 14, 2004 9,303 1,648 214 Acworth, GA Aug 14, 2009 #5 Aug 14, 2009 #5 Sounds about right. I make about 7.8 with my Trick flow 3 cam. The joys of manual brakes. Kurt
