While someguys will poo poo adding weight to a vehicle, I am for it.
Of course this is on an 04 GT, 150 lbs of boxed magazines, does wonders for a little extra help with Blizzaks.
I used to run around with 400lbs in the back of my Ranger Pickup and I could hang with the four wheel drive boys.
****understand that you will change the car's handling characteristics***
You want to make sure, such as your sandbags, they can't easily shift around. If you are in a spin and the weight shifts, it can make things worse and has been proven to do so.
Knowing your car as well as your dork is the best defense against the white stuff.
Passed a truck at 40 this morning, at a 45 degree angle to him, while in second gear and at about half throttle. A power-pass-drift is what I would label it as. I've also been racing around in go-karts since I was seven and didn't give that up until I bought my second set of wheels.
Most accidents occure because:
1) People have yet to take their car in an open parking lot and practice with it
2) People are taken by surprise (STAY ALERT)---- you need to always expect, predict what your pony could do try and buck you off
3)People Panick---- DON'T ---laugh it off, you're the driver, make the car do what you need it to.
4) Listen to the little voice in your head, if you have doubt, you obviously aren't prepared to handle anything outside of your safety zone, so don't try it out in pubic.
5) Set the car up to your liking---- People on here will tell to do or don't do things and someone always comes along to dispell the myth...It's your ride, properly equip it to do what you want/need it to do in the manner in which you expect it to.
Good luck and drive safe.
