how much weight??
  • Thread starter Thread starter t69r00p69
  • Start date Start date May 10, 2004
t69r00p69
260
Houston, Tx
May 10, 2004
  • May 10, 2004
does a 5 lug conversion add alot of weight or is it mostly the wheels you choose to purchase?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 10, 2004
  • May 10, 2004
The only additional weight from the conversion should theoretically be the extra stud, though the hole for it probably counteracts that some. So in that case, I'd say it depends on the wheels you pick.
85GTlover
704
  • May 10, 2004
I would say generally No and No whatever it is will be minimal the tires and rims are still the same size and the four extra studs cannot weigh much....you will not notice any difference. The only real benefit is there is a much bigger selection of 5 holes than 4.
Starscream88
1,277
Park Ridge NJ
May 10, 2004
  • May 10, 2004
If your planning on a rear disk convertion wouldnt that "save" a little weight?
Drums are heavier than disks right?
Or would it be about equal?
For hindsight I have a scale at work and I weighed my car the weekend out of curiousity,
My car weighed in at 3180 lbs and I havn't ever thought of weight saving,
Its fully loaded, and all my mods are in my sig,
t69r00p69
260
Houston, Tx
May 10, 2004
  • May 10, 2004
thanx DUDES!!! yall are so much help thank goodness for inter net another ? about how much would the conversion cost i know it's not over $600.00 dollars right?
t69r00p69
260
Houston, Tx
May 10, 2004
  • May 10, 2004
come to think of it im gonna get the 390 gear ratio anyway so i should be alright right?
sxystev0
48
Fairfax Virginia
May 10, 2004
  • May 10, 2004
do they make a speedo gear for the 3.90?
85GTlover
704
  • May 10, 2004
I would think they would. You can get them for all the others so I would figure it should be no different. Why not 4.10's? They would be better? (argueable I guess) but it is not a problem on highway and gas issues.......cannot be much more than 3.90's IMO.....I am ditching all things I can.Everything within reason, maybe even bolts here and there.....3 lugs instead of 4 etc. and all smog and wires etc, fog light bracket.....its huge....I am going to fab up new small brackets or ditch the fogs and put screens and maybe cool the front brakes....I want 4.10's.
t69r00p69
260
Houston, Tx
May 11, 2004
  • May 11, 2004
i mean i have 410's on the 99 but for the 91 i dont know i think 390 would be a little better or maybe 373's still kinda debating
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 11, 2004
#10
  • May 11, 2004
  • #10
i think 50resto makes a kit for 399.95. http://secure.50resto.com/product1.cfm?SID=1&Product_ID=2514&Category_ID=1174
t69r00p69
260
Houston, Tx
May 11, 2004
#11
  • May 11, 2004
  • #11
thanx for the info i might do the 5 lug swap more then likely i will more wheel options
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
