How much will a stock driveshaft handle?
pdw5000
37
I have a 68 mustang coupe with a stock driveshaft and I was wondering what would be the torque limit for that shaft.
I am running a 408W stroker with a C4 and a 9" with 4.11 gears. I also run MT ET Streets. I would estimate the torque well above 500 ft/lbs currently.
the stock driver shaft will handle the power, but the stock U joints are suspect. also the stock drive shaft is rather heavy, and will have some balance issues at higher rpms. over all the best thing you can do is order up a new shaft with larger U joints from a place like inland driveline.
Wouldn't worry about the driveshaft itself.
Following what the other poster said, you might look at aluminum Aerostar (i think thats what some people here used) driveshafts. They can be found cheap and are both strong enough for your app and lighter than stock driveshafts.
NOOOO, ditch it.9.0-1 302, AFR 185's, and 125 broke it on the dyno. Not even from shocking it at the track. On the dyno at about 125. Twisted it into two. The thing had cardboard inside, and was extremely thin. Took out a lot of good parts when it went.
I generally agree with that, and probably even for this scenario if it hadn't happened to me.It took out my entire exhaust,cracked my bell housing, stall touched the back of my block and tore out two studs, broke the tranny pump and tail shaft. I was able to fix everything but the converter and it still cost me 750 to fix it, not including my exhaust. :(
