with that gear i think you want the white, 23 tooth speedo gear. changing one is cake. get under the car, look for a plug on the driver side, rear of transmission, it's just above all the hangars for the mid pipe. disconnect electrical plug, remove 11mm bolt, pull sensor out of transmission, and you'll see the gear. there is a circlip retaining it on the sensor, just pop it off, replace speedo gear, and slap it back together. takes 10 mins. a shop will probably charge you a good bit for that, hope that helps...good luck manBPH90LX said:Anyone know where I could find out how to change the speedo gear to fix the MPH? Previous owner went to 3.73's and it wasnt done.
