How the hell do I get the harmonic balancer off?
  • Thread starter Thread starter PJB
  • Start date Start date Sep 28, 2006
P
PJB
131
Rotterdam, NY
Sep 28, 2006
  • Sep 28, 2006
Im installing underdrive pullies and just need to do the crank pulley now but I cant get it or the harmonic balancer off.
I removed the center bolt and Im using a harmonic balancer puller but I cranked down on it as hard as I can and now the crank turns with the puller.
Is there something Im doing wrong?
Im not even sure that the harmonic balancer needs to come off but the pulley wouldnt come off by itself. Does the harmonic balancer even need to come off?
5ive.oh
195
Rocky Mountain House, AB
Sep 28, 2006
  • Sep 28, 2006
No leave it on. It won't come off because th middle of the puller is not centered in the bolt hole correctly, or too large and pushing on the dampner itself. Undo the bolts on the pulley and tap it a bit to loosen it away from the dampner.
RYC CUKR
1,437
Orlando
Sep 28, 2006
  • Sep 28, 2006
No need to remove the balancer to swap the pulley.
Just undo the bolts holding the pulley to the balancer and give it a few taps
On a side note when pulling a balancer remove the balancer bolt and the large washer as well otherwise the balancer won't come off.
P
PJB
131
Rotterdam, NY
Sep 28, 2006
  • Sep 28, 2006
Got it. Thanks for the help.
BTW, I did remove the HB bolt and washer.
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 10, 2025
gkomo
Engine Cant get harmonic balancer puller to work… crank just spins
  • AnthonyA1234
  • Aug 26, 2023
8K
Fox 5.0 Mustang Tech Aug 27, 2023
AnthonyA1234
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Fox Proper way to change a harmonic balancer?
  • AnthonyA1234
  • Apr 13, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 21, 2023
rednotch
