How to attach a degree wheel to a crank?
Comp sells a $30 tool for this that holds the wheel and allows you to spin the crank independently. But I don't know if its worth the money. Other wheels come with aluminum bushings that center the wheel and use the damper bolt to install. Do the bushings work? Is the tool worth it? What are you guys using? Thanks
