Engine degreaser, brake cleaner, high pressure washer or a hose.DavidNC said:I gettin a junkyard explorer lower intake manifold ready for install, but the bottom has an 1/8th inch of oil crude. Half of the area is also covered by a metal plate. How do I get rid of this?
ss93cobra said:Engine degreaser, brake cleaner, high pressure washer or a hose.
Paul Perreca said:is there something bolting it on?
DavidNC said:It not actually bolted doe, it looks like for large round rivit heads holding it down. The be press into the manifold, but I don't want to start prying without know for sure.
tmoss said:Yeah, they are press in rivets. If you remove them DO NOT try to reuse them. YOu have to drill/tap the holes and put small bolts in - not much trouble really.
