So Im going to take my car out of the body shop to get started on the column, after it was stolen... I was wondering which terminal to touch to get to start from there, if you guys could get a diagram posted, I'd appreciate it.. thanks!!:SNSign:
.yeah I kinda noticed that, he he, sorry I gues yeah I am saking how to "hotwire" and yeah I know it's stupid to ask about it online but I kinda need ta since when I got the GT stolen, they f'ed up the ignition switch..nidyanazo said:A bumpstart is when you are in YOUR car and put the tranny in 1st with the clutch in. Then have your buddies push it/roll down a hill and drop the clutch.![]()
notchback said:pretty sure it's the 2 small posts ....not the ones where batt cables hook on
jrichker said:This will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
To crank the engine without a key, remove the small red push on wire from the starter solenoid (or relay if you prefer) and jump it to the solenoid post that connects to the battery.
Be advised that this does not provide power to the ignition system, fuel pump or computer. It will not start the engine, only cause the starter to crank the engine.
beats me too, but I may have an asnwer when i get the car home...88GT17MA said:pardon my stupidness, what is that red push on wire actually for?
Turning the ignition switch to the crank position puts battery voltage on the red push on wire for the starter solenoid. That enegizes the solenoid and closes the contacts for the starter power.Car RamRod said:isnt the red push on wire the ignition relay. Because when you put 12v to that from the hot lead off the battery, it cranks then engine.
Absolutely yes. That's what I do when I am working under the hood and need to crank the car. Just be sure to remember the warning about having it in neutral or Park.wazazzle said:can't you just use a remote start button?
soa remote starter would work, eh? but that wouls only crank the engine or actually start it? sorry i honestly dont know, and i guess hook it up to the 2 big posts, right? thanks...jrichker said:Absolutely yes. That's what I do when I am working under the hood and need to crank the car. Just be sure to remember the warning about having it in neutral or Park.
It will just crank the starter.At1Maverick69 said:soa remote starter would work, eh? but that wouls only crank the engine or actually start it? sorry i honestly dont know, and i guess hook it up to the 2 big posts, right? thanks...
