How to change spring perches?
Dothang67
133
Just got my new roller spring perches from OT and I am anxious to install them. I searched but I only found reviews about them.
For what I see, it seems that the coil spring needs to go out to install them, right? does that involve an alignment after? whats the proper way to do it?
Andrew
yup, basically it helps to do the LCA, UCA, Shelby drop, Spring replacement, all in one shot. But replacing the spring perches will require:
1. Removal of shocks and springs
2. That spring shock tower cover on both sides
3. and the tires
then you just unbolt the perches and reinstall the springs shocks etc...
you shouldn't need an alignment change after just the SPs
seriously, those OT SPs are amazing.
It's not that hard
Spring perches?
- Raise car, support with jack stands.
- Remove shocks
- Compress spring w/ internal spring compressor
- Remove the two 1/2 nuts on the bottom of old spring perch
- Replace spring perch
- Uncompress spring, reinstall shock
- Do the other side
Shouldn't take more than 30 minutes a side.
I wouldn't take the spring out, it's a wasted step IMO.
Not trying to hijack your thread, but one of yall mentioned something about removing the outer shock tower? Is this neccesary? I`m about to do the shelby drop too.
If you want/need to remove the spring then yes. I guess if you used one of those upper type spring compressors you would not need to remove the tower. Either way it's only 6 bolts and not hard to take off.
I had no idea....
I guess I`ll go pull them off, I`m changing springs and everything else too? I got a guy coming over later to cut these old springs ouit with a cutting torch, anyone else think this is a good idea?
I've had my car since 1984, and I've rebuilt the front end at least four times in that period.
I've had the spring shield off exactly once. And it was because I wanted to paint them. Hell, they are off now!
You can absolutely get the spring out without taking them off.
