How to check codes?
  • Thread starter Thread starter Black 93 Fox
  • Start date Start date Jan 6, 2004
Black 93 Fox
1,995
Vancouver,Washington
Jan 6, 2004
  • Jan 6, 2004
How do you check codes on a 93 5.0 LX hatchback? Do i need some kind of computer?
Black 93 Fox
1,995
Jan 6, 2004
  • Jan 6, 2004
Would auto zone check my codes? If i remeber right they do codes for free would they have the stuff for a 93 or is it too old?
TrophyHead
1,195
11
49
PA
Jan 6, 2004
  • Jan 6, 2004
Your check engine light has to be on for autozone to check codes. But you could just tell them its on.
I bought mine from wal-mart for 25 bucks. You plug it in by the brake booster under the hood. There are 2 plugs theres one for the ground and the other one is for the computer. Pretty cool little device you can check you cylinder balance with it also.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 6, 2004
  • Jan 6, 2004
http://dalidesign.com/hbook/eectest.html
Black 93 Fox
1,995
Jan 6, 2004
  • Jan 6, 2004
Thanks Grover Dill and Trophy Head.
M
mr.p
26
Columbus, Georgia
Jan 6, 2004
  • Jan 6, 2004
Question along the same lines, my check engine light is on, but I am receiving no codes. There are other anomallys that are ocurring (bad idle, hard start, high TPS voltage, fuel pump runs constantly) that may all point to a common thing. Anyone seen any of these problems (the high TPS voltage, 4.25, and constant running fuel pump are my main concern)?
Thanks,
David
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 6, 2004
  • Jan 6, 2004
Thanks,
David
Bad or missing grounds...
Grounds are important to any electrical system, and especially to computers.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
3.) The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
4.) All the sensors have a common separate ground. This includes the TPS, ACT, EGE, BAP, & VSS. It is pin 46 on the computer
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally.
If you have access to a digital voltmeter and would like help diagnosing grounds, make another post and I will try to help.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
M
mr.p
26
Columbus, Georgia
Jan 6, 2004
  • Jan 6, 2004
jrichker,
Thanks for the info, after reading your post I am going to spend some time with it tonight. I do have a digital multimeter so if you don't mind providing additional assistance, I would be most appreciative.
Thanks,
Dave
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 7, 2004
  • Jan 7, 2004
mr.p said:
jrichker,
Thanks,
Dave
The basic premise is to measure the voltage drop accross a connection by placing the DVM test lead on the wire and the other on the other side of the wire or connection. Measuring the drop across the wire or connection shows how good the connection is: you should have less than .5 volts drop.
To find high resistance connections, and excessive voltage drops, put one voltmeter lead on the negative battery post and one on the engine block. Then try to start the car: more that .5 volt drop indicates a dirty connection or bad cable: next try from negative battery post to body ground at the firewall.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Interior and Upholstery 87-93 Mustang Metal Side Headliner Trim Clips Upper Hatchback Coupe Door OEM 524
  • Noobz347
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
