I've got the front end of my car jacked up and disassembled, and while I was under there I thought it would be a good idea to do some clean up and paint for protective reasons. I'm looking to do this to protect the metal at this point rather than as a high quality restoration. I don't own an air compressor or paint gun, so I will probably have to use cans of spray paint - is that acceptable?
The lower parts of the under-side of the car have a good layer of grease/oil/grime, and the upper parts have some light surface rust. I scraped some of the lower grime off with a flat-blade screw driver and the metal underneath appears to be in great condition.
How should I go about cleaning and prepping all this for paint? Wire brush, de-greaser, sand paper? Is there anything special that needs to be done to the surface rust, or can it just be cleaned up(with a wire brush, etc) and primered?
