How to correctly perform a compression test?
1poorguy
I'm a newbie at this car stuff, so I want to be sure that I don't break anything ;) What sort of tools do I need and what numbers are to be expected from a decent engine?
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
A battery charger to charge the battery while you are testing will help to insure consistent results. If the battery gets weak, the last cylinders will not read accurately.
