How To Do A Compression Test On My Car?
1. Remove all spark plugs. This allows for even cranking/breathing.
2. Disable fuel by disconnecting the fuel pump relay or pulling the fuse. If you only disable spark, then you will still get fuel injected during cranking.
3. Install compression gauge and crank car with the throttle fully open.
4. All the cylinders should be within 10% of each other.
5. It would help to put a battery charger on if you have one so that full cranking speed is achieved.
