How to find TDC???
  • Thread starter Thread starter A67StangMaster
  • Start date Start date Sep 13, 2006
A67StangMaster
401
San Jose CA
Sep 13, 2006
  • Sep 13, 2006
I am soo lost on how I am supose to find the TDC and the compression stroke?? Can some one be more detailed?
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Sep 13, 2006
  • Sep 13, 2006
With the engine all together take out the number 1 spark plug, pull the coil wire so it dont start and ether crank it over with a wrench or tape it over with a screwdriver on the solenoid. stick your finger in the # 1 spark plug hole lightly and crank it over by a wrench or by TAPING it on the solenoid.
You wil feel the compression stroke pushing on your finger, that meens that the piston is coming up on TDC, stop and look at your damper and the TDC mark should be coming up to the pointer, Wrench it up till the line is on TDC.
Done.
A67StangMaster
401
San Jose CA
Sep 13, 2006
  • Sep 13, 2006
But I dont have a line on my damper? and dosn"t it compress on exhaust to? so how would I know which one it is?
Spoofty
61
  • Sep 14, 2006
No, because the exaust valve is open.
jerry S
1,365
52.22N 5.12E
Sep 14, 2006
  • Sep 14, 2006
even if you don't have a line on the damper, you should still have a timing pointer. take a piece of white chalk and scribe a line on the damper where the pointer points after finding TDC.
http://www.msdpowersports.com/2004_faq.html#tdc
How do I find Top Dead Center (TDC)?
TDC is where the piston has reached its highest point in the cylinder. It is the foundation to accurate timing. To find TDC, remove the spark plug and use a plunger depth gauge to judge where TDC is. If you don't have a depth gauge, place a screwdriver thru the spark plug hole until the screwdriver rests on top of the piston. Turn the flywheel until the screwdriver reaches its highest point, make a reference mark on the flywheel and a reference point on the case. Then reverse the rotation of the flywheel, allowing the screwdriver to lower down and come back up again to its highest point. Make another reference mark on the flywheel. If the two points match up - consider yourself lucky because you have an accurate crank/connecting rod/piston assembly. If the two marks don't match up, pick the point exactly between your two reference marks (using the points closest together) - this is true TDC.
Shakin66
628
Waycross, Ga / Lake James, NC
Sep 14, 2006
  • Sep 14, 2006
Yea, thats the way to do it. I have been using a slightly wet paper towel stuffed into the #1 Cylinder and turing it over by tapping on the Sol. in short burst as you dont want to pass TDC. As soon as you hear and see it pop out you are very close. Then you can roll the engine over with a 15/16" socket on the harmonic balancer to get to true TDC. You lucky since I am running a roller motor the S/C is right in the way of the timing marks but by doing this it fired right up. Good luck!
Spoofty
61
  • Sep 14, 2006
You could also buy timing tape. That's what I did, makes it very easy to set timing.
Only $3.95 from Summit
http://store.summitracing.com/partdetail.asp?part=SUM-163594&N=700+-106059+115&autoview=sku
A67StangMaster
401
San Jose CA
Sep 14, 2006
  • Sep 14, 2006
well i found a old timming mark on it but I have a new cam?? dose that make a differance?
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Sep 14, 2006
  • Sep 14, 2006
Your TDC is always The same no matter what cam you put in.
You can advance or retard the cam timing but TDC is always the same.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
K
Engine rebuild in connecticut
  • Kngtmare
  • Aug 30, 2026
Potomus Pete
New to forum
  • 67 blueberry
  • Jul 2, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 19, 2026
infamous
